In the instructions, just before the “Select Cesium World Terrain as your reference terrain in the tiling options” sentence, you could add this sentence: “Answer the ‘What kind of data is this’ question with ‘KML/COLLADA (Tile as 3D Tiles)’.”
N/A
The following sentence tells the user to use a form control that isn’t in the UI unless the user previously takes the step described above. The step is guessable, but the instructions are otherwise step-by-step, so including this step seems reasonable.
Version 2020-02-11. OS X 10.13.6. Chrome 80.
