I have loaded a GeoJSON file into Cesium as shown in point 2.
The GeoJSON consits of 3 regions and each region has a lot of several features in it with some information I can request when clicking on it in the Viewer.
Is there a possibility to access each single feature based on the information assigned to the feature? E.g. every feature has a value for "Height above ground" and I want to colorize any feature that lies between a defined range in this criterion.
var geojsonDataSource = new Cesium.GeoJsonDataSource();
var geojsonUrl = 'data/test_lf_20190624_lv95.geojson';
viewer.dataSources.add(geojsonDataSource);
geojsonDataSource.load(geojsonUrl).then(function () {
viewer.flyTo(geojsonDataSource);
Colorize features based on defined criterion ranges.
Cesium v.1.58
Chrome 75.0.3770.100
