Hi all,
I am not able to add rows to infobox within a loop. Each time the infobox gets replaced instead of getting appended.
Below is a part of the code infobox. I am trying to append to the table by in the loop but the output doesnt get affected
var featureName = pickedFeature.getProperty(‘name’);
selectedEntity.name = featureName;
selectedEntity.description = 'Loading
';viewer.selectedEntity = selectedEntity;
selectedEntity.description = ‘
| BIN | ’ + pickedFeature.getProperty(‘BIN’) + ‘ |
| DOITT ID | ’ + pickedFeature.getProperty(‘DOITT_ID’) + ‘ |
| SOURCE ID | ’ + pickedFeature.getProperty(‘SOURCE_ID’) + ‘ |
My requirement is to loop through and display as many rows in the infobox as the length of the loop.
cesium version I am using is 1.51, OS is windows 10 and browser is Chrome
- A concise explanation of the problem you’re experiencing.
- A minimal code example. If you’ve found a bug, this helps us reproduce and repair it.
- Context. Why do you need to do this? We might know a better way to accomplish your goal.
- The Cesium version you’re using, your operating system and browser.
