Are Cesium sensors deprecated?
Hello!
I wonder if Cesium sensors are deprecated now? I can’t find anything in the official docs, just a few examples on this site eg. http://help.agi.com/STKWebVisualizationLibrary/RectangularSensor.html but they are not working.
I’d like to display sensor measure ranges on Cesium map.
1.57.0
It was renamed to the ion analytics SDK! You can read about it here: https://cesium.com/ion-sdk/
thanks, but unfortunately ION sdk is a paid service. Really is there no other way to use? Has anyone worked with svg-s within cesium map? used this on Leaflet for a 2d project to display sensor measure ranges.
cheers
  1. május 17., péntek 15:59:45 UTC+2 időpontban Omar Shehata a következőt írta:
For SVGs, none of the code examples on Sandcastle use it, but any example that uses an image can be replaced with a link to an SVG. For example:
https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=Billboards.html&label=All
What kind of project are you working on? Do you need real-time visibility analysis, or are you just trying to mark areas of visiblity that are known ahead of time?
