I’m trying to attach an event to the infoBox so that when it is open, I can add more content.
I looked into InfoBoxViewModel showInfo but I couldn’t find how I would access this Knockout variable. Additionally, I was thinking about:
handler.setInputAction(function(e){
// add jQuery code to add event in a setTimeout
},Cesium.ScreenSpaceEventType.LEFT_CLICK);
Any ideas?
I’m probably thinking about this very backwards.
This does what I want but it’s pretty sketchy…
$(".cesium-viewer-infoBoxContainer").on(‘mouseover’, function(e){
$("#editar").on(‘click’, function(e){
e.preventDefault();
that = $(this);
href = that.attr(‘href’);
dialogCedulaPopUp(href); // open dialogue
Still learning Knockout which would be better in this scenario most definitely.
To subscribe to the observable showInfo boolean property:
Cesium.knockout.getObservable(viewer.infoBox.viewModel, ‘showInfo’).subscribe(function(newValue) {
The function will be called whenever showInfo changes, and newValue will be true or false.
Thanks a lot, Scott!
I’m just getting around to learning subscriptions in Knockout.
While you’re learning Knockout, keep in mind that Cesium also uses the knockout-es5 plugin to expose observable data as properties for ease of use. The call to getObservable is part of the es5 plugin, not regular Knockout.
http://blog.stevensanderson.com/2013/05/20/knockout-es5-a-plugin-to-simplify-your-syntax/
Thanks for the explanation and link!
