Is it possible to blend the Black Marble tiles with e.g. Bing depending on daytime? So that the globe shows lit up cities in night areas but the Bing ones where it’s daytime?
Hi @omar thanks! Is it possible to fade the night layer away as you scroll into the earth / increase zoom level? So the night layer is only shown from far away?
You can use the camera moveStart event listener and check for the height of the camera each time it moves. If the height has passed a certain threshold, you can then turn off the night layer.
