I’m using Camera flyToBoundingSphere to move from a large area to a smaller area.
During the fly if some conditions are met (range, height) new labels are created with the names of the cities, previously retrieved.
The problem is that when new labels with cities names are created, the fly “freeze” for a while. It’s very noticeable and very annoying.
What is strange is that this problem does not seem to appear if I use a default text in place of cities names.
function zoomIn() {
boundingSphere.radius = 7000;
viewer.camera.flyToBoundingSphere(boundingSphere, {
duration: 8,
easingFunction: Cesium.EasingFunction.QUADRACTIC_IN_OUT,
export function drawLabel(position, text, category, collection = null) {
let properties = getPropertiesFromCategory(category)
// if (text.length > 15) text = stringDivider(text, 15);
let entity = viewer.entities.add({
opacity: 1, /// default value at start
minDistance: properties.minDistance,
maxDistance: properties.maxDistance,
fillColor: properties.fillColor,
outlineColor: properties.outlineColor,
position: position,
label: {
text: text, /// HERE IF I USE “TEXT” IN PLACE OF text THERE’S NO FREEZE FURING THE FLY
font: properties.font,
fillColor: new Cesium.CallbackProperty(function () {
return new Cesium.Color(entity.fillColor.x, entity.fillColor.y, entity.fillColor.z, entity.opacity)
}, false),
outlineColor: new Cesium.CallbackProperty(function () {
return new Cesium.Color(entity.outlineColor.x, entity.outlineColor.y, entity.outlineColor.z, entity.opacity)
}, false),
outlineWidth: properties.outlineWidth,
style: properties.style,
verticalOrigin: properties.verticalOrigin,
heightReference: properties.heightReference,
pixelOffset: properties.pixelOffset,
disableDepthTestDistance: properties.disableDepthTestDistance,
/// register the listener to camerachanged,
/// to update this label opacity
viewer.camera.changed.addEventListener(() => {
let pos = entity.position._value;
let dist = Cesium.Cartesian3.distance(viewer.camera.positionWC,
pos);
/// get multiplier by min-max range
let rangeMult = 1 - Math.inverseLerp(minRange, maxRange,
Cesium.Math.clamp(dist, minRange, maxRange));
/// get multiplier by min-max distance
let distMult = 1 - Math.inverseLerp(entity.minDistance, entity
.maxDistance,
Cesium.Math.clamp(dist, entity.minDistance, entity.maxDistance));
entity.opacity = rangeMult * distMult;
if (collection) collection.push(entity);
function getPropertiesFromCategory(category) {
let properties = {
font: “300 15px Roboto”,
outlineWidth: 2,
fillColor: new Cesium.Cartesian3(1, 1, 1),
outlineColor: new Cesium.Cartesian3(0, 0, 0),
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
heightReference: Cesium.HeightReference.NONE,
pixelOffset: new Cesium.Cartesian2(0, -5),
disableDepthTestDistance: Number.POSITIVE_INFINITY,
minDistance: 50000,
maxDistance: 800000,
switch (category) {
case “A1”:
properties.font = “700 20px Roboto”;
properties.outlineWidth = 2;
properties.minDistance = 800000;
properties.maxDistance = 2000000;
break;
case “A2”:
properties.font = “700 18px Roboto”;
// properties.fillColor = new Cesium.Cartesian3(.2, .5, .9);
properties.minDistance = 170000;
properties.maxDistance = 800000;
break;
case “A3”:
properties.font = “500 16px Roboto”;
properties.fillColor = new Cesium.Cartesian3(.9, .5, .2);
properties.minDistance = 130000;
properties.maxDistance = 500000;
break;
case “A4”:
properties.font = “500 14px Roboto”;
properties.fillColor = new Cesium.Cartesian3(0, 1, 1);
properties.minDistance = 60000;
properties.maxDistance = 100000;
break;
case “A5”:
// properties.fillColor = new Cesium.Cartesian3(1, 1, 1);
properties.minDistance = 35000;
properties.maxDistance = 75000;
break;
return properties;
To create label entities only when some camera conditions are met
1.66
