I am running Cesium v1.4.1 inside Cordova, my application is picking up the correct position from the device, however the negative value for latitude is ignored and the camera ends up positioned in the wrong hemisphere.
I have tried casting to a Number, two significant figures and even reversing the parameter to no avail.
Thanks in advance
Duncan
function flyToPosition(pos) {
var latitude = Number(pos.coords.latitude).toFixed(2);
var longitude = Number(pos.coords.longitude)toFixed(2);
console.log(latitude);
console.log(longitude);
viewer.camera.flyTo({
destination: Cesium.Cartesian3.fromDegrees(latitude, longitude, 4000000),
duration: 0
var options = {
enableHighAccuracy: true,
maximumAge: 3600000
function onError(error) {
alert('code: ' + error.code + '\n' + 'message: ' + error.message + '\n');
navigator.geolocation.getCurrentPosition(flyToPosition, onError, options);
I would like to have the app start out above the current location for the user.
Cesium v1.41, Android 7.0 & Chrome 65.0.3325.109
