Can I Change Right_Click to double tap on Mobile?
is there any way to replace RIGHT_CLICK with touch when i visit my web with iphone, because polyline drawing feature need to use RIGHT_CLICK but on iphone it can only tap, can i change right click to double tap?
Hi @Yen_Woody,
I recommend checking out the ScreenSpaceEventType documentation.
https://cesium.com/learn/cesiumjs/ref-doc/ScreenSpaceEventType.html
This documentation shows you what types of input CesiumJS recognizes. You can use this documentation to create your own custom logic for converting between input types.
-Sam
I’ve read it but still don’t quite understand, can I use PINCH_START instead of right-click for touch?
@Yen_Woody
It just depends on your use case! I believe that on touch screens, a touch input is equivalent to a LEFT_CLICK. Thus, you could replicate a “double-tap” input by accepting two rapid left clicks. Once you receive a double tap input, you could trigger a RIGHT_CLICK event.
-Sam
well, i try to use PINCH_START and it work
@Yen_Woody
Great! I am happy to hear that you found a solution.
-Sam
