Cesium for Unreal 2.28.0 – Token Window Stuck with 404 Error on UE 5.7
I’m having an issue with Cesium for Unreal 2.28.0 on Unreal Engine 5.7.
After successfully signing in to my Cesium ion account, when I click the “Token” button, the “Select a Cesium ion Token” window remains stuck on the loading animation and no tokens are displayed.
The Output Log repeatedly shows:
LogCesiumEditor: Error: Received response code 404 (Code 404)
I tested this with:
  • Unreal Engine 5.7
  • Cesium for Unreal 2.28.0
  • A completely new Unreal project
  • A new Cesium ion account
  • A new access token
  • Cleared the Cesium request cache
The issue happens consistently, even in a completely empty project.
Any idea what could be causing this 404?
Thanks!
I have same problem, my Engine Version is 5.5 and Cesium for Unreal Version is 2.28.0
I switched to version 2.27 and still have the same problem; this looks like an issue with the official server.
Same issue. Tried using UE 5.7 and 5.8.
Error code:
Hi @Saif_Khaloui, @3503933149, and @Rmw2g, thanks for reporting this, and for the extra confirmation from multiple setups.
The fact that this reproduces across UE 5.5, 5.7, and 5.8, and across plugin versions 2.27 and 2.28, tells me this is likely a server-side issue rather than anything in the plugin itself. I’m going to check with the team internally and will follow up here once I have more information. I am also able to repro this locally.
In the meantime: are any of you able to load tilesets or other ion assets normally using the “Ion Asset ID” and “Ion Access Token” fields in the Tileset’s details panel (just the token selection panel is broken), or is all ion access failing? That would help narrow down whether this is specific to the token-listing API endpoint or a broader authentication issue. You can also check whether ion.cesium.com loads and shows your assets normally in a browser.
I created an issue in the cesium unreal github here: Select Cesium ion Token" panel returns 404 - no tokens load · Issue #1881 · CesiumGS/cesium-unreal · GitHub if you want to follow for updates, but I will also endeavour to post here too
In fact, I can only not get the token list in newly created projects. Even though I also can’t get it in projects that already have tokens bound, the map services can still load normally. I guess it’s because the original services already had tokens bound, so they can still display correctly.
Looks like the issue is fixed! Thank you so much for the prompt reply and fix! you guys are awesome!
This has been resolved with https://github.com/CesiumGS/cesium-ion/pull/9783. Thank you all for the detailed reports!
