My Tomcat uses it. Is there anyway to change Cesium from 8080 to another port. Or do I have to change tomcat?
To change the port, pass -DrunServer.port=X, where X is the desired port.
https://github.com/AnalyticalGraphicsInc/cesium/wiki/Contributor’s-Guide#build-targets
Good afternoon,
The referenced documentation for this appears to have been moved/deleted. I’m uncertain where to put this flag to change the default port, can you assist?
Thank you,
Darryl
The documentation for the node-based development web server can be accessed by running
node server.js --help
after running npm install
Perfect, thank you!
Darryl
