I have 2 entities associated with the same clipping plane.
I want the clipping plane to “cut” the 2 entities.
At the begining only the first entity is visible (entity.show= true) and the second one is hiden (entity.show=false).
The clipping plane functions perfectly on the visible entity.
Then I hide the first entity and I show the second one.
The clipping plane functions perfectly with the second entity.
When I hide the second entity and show again the first one,
it is clipped at the same place I clipped the second entity when it was visible (that’s normal)
but now the clipping plane can move but it doesn’t clip the first entity as it did at the begining.
I can’t figure what happen.
Perharps a caching problem ?
Thank you for any help.
Dominique
