I cant access http://sergeserver.dyndns.org/phocadownload/terrain.tar.gz . Can you please mail me the whole dump of this terrain.tar.gz. Thanks
http://sergeserver.noip.me/phocadownload/terrain.tar.gz (Don't sure in correct archive)
http://sergeserver.noip.me/phocadownload/gdal2srtmtiles.tar.gz (Not more supported)
Why you not use GeoserverTerrainProvider ?
Thankyou so much for a prompt reply!
This link worked: http://sergeserver.noip.me/phocadownload/terrain.tar.gz
But is this whole globe elevation data ?
For using GeoserverTerrainProvider, i will need to host geoserver data right ? The geoserver data is of which format , .bil ?
Where do i get this data from ?
Actually, for the below code:
var terrainProvider = new Cesium.GeoserverTerrainProvider({
url : “http://localhost:8080/geoserver/wcs/wms”,
layerName: “wcs:clip11(reproject)”,
waterMask:true
globe.terrainProvider = terrainProvider;
Where do i get the geoserver folder from?
[The geoserver folder to be hosted at 8080]
Thanks.
I have got the geoserver setup done and started geoserver at 8080.
For offline elevations, i wrote the below code:
var globe = new Cesium.Globe(Cesium.Ellipsoid.WGS84);
url: “http://localhost:8080/geoserver/ows?service=wms&version=1.3.0&request=GetCapabilities”,
//layerName: “SRTM90”,
//styleName: “grayToColor”,
waterMask: false
BUT, i cant see any elevations ! What am i missing?
Please guide.
Have you solved the water mask problem in cesium, can i get some sugestions about adding water mask data to generate the terrain tiles?
在 2017年5月18日星期四 UTC+8下午12:50:36,nigamr…@gmail.com写道:
If you have raster data with water represented in it, can you describe whether it’s represented as void, as mean sea level, or something else? We have an open feature request for this here: https://github.com/AnalyticalGraphicsInc/cesium-ion-community/issues/224
