Customize Clustering By multiple conditions
Hello,I want to know if it is possible to set multiple aggregation conditions? For example, aggregation based on distance in the same area(Data in the same state is aggregated based on distance, while data in different states will not be aggregated).
Hi @QianWu184, what do you mean by data being in the same or different states?
For example, I have train station data in each state. I think they cluster according to each state. Is this achievable? What do I need to configure?
That might be tricky; I’m not sure what the best way to about this is. Maybe you could set clusterBillboards/clusterLabels/clusterPoints depending on the state data?
I don’t think that’s what I want. Perhaps storing the same area of data in a DataSource and turning on aggregation would be a solution
Yeah, I’m not sure what the best way is to go about this. Let us know if you have success with your idea :slight_smile:
