When I load czml into my czml datasource via process, It is only ingesting the last value sent through.
In my example below I Sent a property bag named animation through with two intervals with different strings.
When I process this It takes only the last value and I need both.
CZML sent->
properties:
animation: Array(2)
0: {interval: "2019-04-26T21:35:57.38574410000001Z/9999-12-31T23:59:59.9999999Z", string: "scat2"}
1: {interval: "2019-04-26T21:35:57.38574410000001Z/9999-12-31T23:59:59.9999999Z", string: "scat1"}
length: 2
__proto__: Array(0)
animationPercent: Array(2)
0: {interval: "2019-04-26T21:35:57.38574410000001Z/9999-12-31T23:59:59.9999999Z", number: 1}
1: {interval: "2019-04-26T21:35:57.38574410000001Z/9999-12-31T23:59:59.9999999Z", number: 1}
After: module.loadCZML = function(data) {
var czmlData = data.DATA;
console.log('czmlData', czmlData);
czmlDataSource.process(czmlData); // loads the czml into
// cesium
_properties: PropertyBag
_animation: TimeIntervalCollectionProperty
_definitionChanged: Event {_listeners: Array(1), _scopes: Array(1), _toRemove: Array(0), _insideRaiseEvent: false}
_intervals: TimeIntervalCollection
_changedEvent: Event {_listeners: Array(1), _scopes: Array(1), _toRemove: Array(0), _insideRaiseEvent: false}
_intervals: Array(1)
0: TimeInterval {start: JulianDate, stop: JulianDate, data: "scat1", isStartIncluded: true, isStopIncluded: true}
length: 1
__proto__: Array(0)
changedEvent: (...)
isEmpty: (...)
isStartIncluded: (...)
isStopIncluded: (...)
length: (...)
start: (...)
stop: (...)
__proto__: Object
definitionChanged: (...)
intervals: (...)
isConstant: (...)
__proto__: Object
_animationPercent: TimeIntervalCollectionProperty {_definitionChanged: Event, _intervals: TimeIntervalCollection}
I need to check if an animation is fired at a specific time to chane a models animation
