Data and funtionality
Hi there, I’ve attempted to upload the data to Blender, but the output appears in the info panel without showing up in Cesium Ion. Do you have any advice on how to visualize 3D model OBJ data and point clouds in LAS format using Blender and Revit?
I’m just sharing some outputs I’ve gathered with AI so far—still haven’t had a chance to try everything yet.
Data Type File Format Description Usability Notes Visualization Location Properties
Data Type File Format Description Use Case Notes Visualization Location Properties
3D Tiles .json Optimized format for streaming large-scale 3D models, point clouds, and city models Visualizing large city models, buildings, or complex 3D data Best for large-scale 3D geospatial datasets 3D View, Detailed View, Features Interactive Geospatial Data Access Tile Structure, Bounding Volume, Metadata, Textures, Materials
3D Tiles .b3dm Binary format of 3D Tiles for optimized loading and reduced size Large-scale city modeling, LIDAR visualization Optimized for binary data and faster loading 3D View, Detailed View, Features Interactive Geospatial Data Access Tile Structure, Bounding Volume, Metadata, Textures, Materials
3D Tiles .i3dm Binary format for individual 3D model tiles (e.g., buildings) Rendering specific 3D models (e.g., buildings, trees) Optimized for rendering specific objects 3D View, Detailed View, Features Interactive Geospatial Data Access Tile Structure, Bounding Volume, Metadata, Textures, Materials
3D Tiles .pnts Point cloud data format used for large-scale point cloud visualization Visualizing point clouds from LIDAR scans Supports point cloud rendering 3D View, Detailed View, Features Interactive Geospatial Data Access Coordinate System, Point Attributes (RGB, Intensity), Density, Normals
Point Clouds .las LIDAR point cloud format with XYZ data and attributes High-resolution LIDAR data for terrain or object modeling Common LIDAR data format 3D View, Features Interactive Geospatial Data Access Coordinate System, Point Attributes (RGB, Intensity), Density, Normals
Point Clouds .laz Compressed LIDAR point cloud format Reducing storage size while maintaining fidelity Compressed version of LAS 3D View, Features Interactive Geospatial Data Access Coordinate System, Point Attributes (RGB, Intensity), Density, Normals
Point Clouds .ply Polygon file format for 3D point clouds with attributes 3D scanning, model creation Common for 3D scanning and CAD 3D View, Features Interactive Geospatial Data Access Coordinate System, Point Attributes (RGB, Intensity), Density, Normals
Point Clouds .xyz Simple text-based format storing 3D point coordinates Representing 3D point data for custom datasets Basic format without metadata 3D View, Features Interactive Geospatial Data Access Coordinate System, Point Attributes (RGB, Intensity), Density, Normals
Terrain Data .tif GeoTIFF format for storing elevation data as raster Visualizing terrain elevation or creating 3D terrains Ideal for high-resolution raster data 3D View, Features Interactive Geospatial Data Access Resolution, CRS, Height Range, Data Type
Terrain Data .dem Digital Elevation Model format storing 3D terrain data Terrain analysis, flood modeling Often used for large-scale elevation data 3D View, Features Interactive Geospatial Data Access Resolution, CRS, Height Range, Data Type
Terrain Data .hgt Global terrain data representing height values in a grid Elevation and terrain modeling Global coverage for scientific applications 3D View, Features Interactive Geospatial Data Access Resolution, CRS, Height Range, Data Type
Terrain Data .asc ASCII Grid format for rasterized terrain data Used for elevation and raster data Simple, human-readable format 3D View, Features Interactive Geospatial Data Access Resolution, CRS, Height Range, Data Type
Imagery .tif Raster image format for geospatial imagery (satellite/aerial) Satellite imagery for mapping or aerial photography overlays Common for geographic imagery 2D View, Features Interactive Geospatial Data Access Spatial Resolution, CRS, Band Information
Imagery .jpg Compressed image format for raster imagery Overlays for maps or backgrounds in 3D Ideal for web and quick applications 2D View, Features Interactive Geospatial Data Access Spatial Resolution, CRS, Band Information
Imagery .jpeg JPEG compressed format for imagery Web-based imagery and overlays Suitable for fast rendering 2D View, Features Interactive Geospatial Data Access Spatial Resolution, CRS, Band Information
Imagery .png Image format supporting transparency Map layers or overlay requiring transparency Useful for map layers 2D View, Features Interactive Geospatial Data Access Spatial Resolution, CRS, Band Information
Imagery .jp2 JPEG2000 format for high-resolution imagery High-resolution satellite or aerial imagery Typically used for high-quality imagery 2D View, Features Interactive Geospatial Data Access Spatial Resolution, CRS, Band Information
Vector Data .kml XML-based format for geographic features Visualizing points, lines, polygons Ideal for Google Earth and web apps 2D View, Features Interactive Geospatial Data Access Placemark Info, Geometry Types, Time-based Data
Vector Data .kmz Compressed KML format for easier sharing Same use cases as KML but with smaller file sizes Compressed KML format 2D View, Features Interactive Geospatial Data Access Placemark Info, Geometry Types, Time-based Data
3D Models .gltf JSON-based format for 3D models with textures and animations Real-time rendering and visualization of 3D models Open standard for 3D models 3D View, Features Interactive Geospatial Data Access Textures, Materials, Animation
3D Models .glb Binary format of GLTF for 3D models Efficient for delivering 3D models Optimized for streaming 3D View, Features Interactive Geospatial Data Access Textures, Materials, Animation
3D Models .fbx Proprietary format for 3D models and animations Used in game engines and animations Common for game development 3D View, Features Interactive Geospatial Data Access Animation, Textures, Materials
3D Models .obj Common 3D model format Used in modeling and rendering 3D objects Widely used in 3D software 3D View, Features Interactive Geospatial Data Access Textures, Materials
3D Models .stl 3D model format for 3D printing Used in 3D printing and rapid prototyping Focused on mesh data 3D View, Features Interactive Geospatial Data Access Mesh Data
3D Models .dae Collada format for 3D models and animations Used for 3D model exchange between applications Open standard for interchange 3D View, Features Interactive Geospatial Data Access Textures, Materials, Animation
3D Models .x3d XML-based format for 3D models and interactive content Web-based interactive 3D models Used for web visualization 3D View, Features Interactive Geospatial Data Access Textures, Materials, Animation
3D Models .blend Native format for Blender 3D software Used for complex 3D modeling and animation Blender native format 3D View, Features Interactive Geospatial Data Access Textures, Materials, Animation
Geospatial Data .osm OpenStreetMap XML format for geographic data Used for map data, roads, and buildings Open-source geographic data 2D View, Features Interactive Geospatial Data Access Geometry Types, Placemark Info
Geospatial Data .csv Comma-separated values for tabular data Storing geospatial data in simple tabular format Common for custom datasets 2D View, Features Interactive Geospatial Data Access Coordinates, Attributes
Geospatial Data .gpx GPS Exchange format for geospatial data Storing GPS tracks and waypoints Common in GPS-based applications 2D View, Features Interactive Geospatial Data Access Track Data, Waypoints
Geospatial Data .shp Shapefile format for vector data Common format for vector data in GIS Widely used in GIS applications 2D View, Features Interactive Geospatial Data Access Geometry, Attributes
Geospatial Data .geojson JSON format for representing vector data Used in web mapping and geospatial applications Standard for web-based GIS 2D View, Features Interactive Geospatial Data Access Geometry, Attributes
Geospatial Data .gdb Geodatabase format for storing spatial data Used for large-scale GIS data storage Database format for GIS 2D View, Features Interactive Geospatial Data Access Geometry, Attributes
Welcome to the Cesium community!
I’m a bit confused, are you trying to view the OBJ and LAS data in Blender and Revit? If so, you might have better luck by reaching out to those respective communities.
You can export data from Blender or Revit to Cesium ion, but that requires you to manually do the export. It is not something that occurs automatically. Please let us know if you have any problems or questions about this process.
