Double-sided triangles - 3D Tileset
Would there be a large performance hit in cesiumJS if models have been tiled with the double-sided flag? Is there any way to test streaming times?
@TomPovey
I suspect that the runtime performance would not be significantly impacted. However, results may vary based on your use case. Could you please share some more information on your intended application? For instance, how many triangles are you going to stream? What kinds of tests do you intend to run?
-Sam
