Hey devs,
I have been working on an issue for quite a while which is to do with a large update of Cesium.
We have been stuck on an older version for a while due to issues limiting us from moving to latest.
However, I am having issues with the labels. In my existing implementation after upgrading from
“@cesium/engine”: “^18.0.0” → “@cesium/engine”: “^25.0.0”
“@cesium/widgets”: “^12.1.0” → “@cesium/widgets”: “^15.0.0”
“cesium”: “~1.123.0” → “cesium”: “~1.141.0”
When adding a label as simple as
` widget.entities.add({
position: Cartesian3.fromDegrees(0, 0, 0),
label: {
text: 'meow',
Results in the following stack trace
DeveloperError: Expected index to be typeof number, actual typeof was object
Error
at new DeveloperError (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:7366:11)
at Check.typeOf.number (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:7421:11)
at Check.typeOf.number.greaterThanOrEquals (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:7451:16)
at TextureAtlas.computeTextureCoordinates (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:45798:31)
at BillboardTexture.computeTextureCoordinates (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:130751:16)
at Billboard.computeTextureCoordinates (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:131745:29)
at writeCompressedAttrib0 (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:132577:38)
at writeBillboard (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:132826:3)
at BillboardCollection.update (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:133037:9)
at LabelCollection.update (https://HOST/node_modules/.vite/deps/@cesium_engine.js?v=c6158d33:136003:28)
Now where this gets tricky! I cant reproduce this in sandcastle or a new react project.
I would appreciate all the help ![]()
Cheers
