I'm quite new to Cesium (I'm impressed) and would like to load my own kml-file 'MyKML.kml' which results in the error message 'Request has failed. Status Code: 403'. The same kml-file loads fine e.g. in Google Maps Pro. Here is the code:
viewer.dataSources.add(Cesium.KmlDataSource
.load('../../SampleData/kml/MyKML.kml', {
camera: viewer.camera,
canvas: viewer.canvas
.then( function (dataSource) {
viewer.flyTo(dataSource.entities);
Running the same code example with the 'bikeRide.kml' file provided by Cesium (tutorial) works fine:
.load('../../SampleData/kml/bikeRide.kml', {
I'm running Cesium in a Mac Safari browser, and the two kml-files show the same permission/access rights. What am I doing wrong? Thank you for advise!
Guido
