Image material alters URL when the URL is very long
I’ve created a Sandcasle script (two of the links will expire in 7 days)
You can select the image used. First two options work well, while the last option ‘Presigned URL long’ fails to display the image
If you just copy the presignedLong and navigate to it, or use it in in HTML element, it works fine. but when used as Cesium image material, it fails to load. Looking in developer console, you can see that it is trying to load image from another URL (some parts of the URL are deleted)
presignedShort was generated by signing it with IAM credentials
presignedLong was signed using security token authentication
How can it be fixed?
We use AWS S3 to store images in a GIS solution and generate AWS Presigned URL for to allow user’s browser to load it.
Cesium 1.67, 1.57
Chrome Version 80.0.3987.149 (Official Build) (64-bit), Microsoft Edge 42.17134.1098.0
Windows 10
