# Forbid camera access below 3DTiles
**URL:** <https://community.cesium.com/t/forbid-camera-access-below-3dtiles/16261>\
**Category:** CesiumJS\
**Created:** [November 23, 2021, 3:20am UTC](https://community.cesium.com/t/forbid-camera-access-below-3dtiles/16261 "2021-11-23T03:20:52Z")\
**Showing post:** 7
**Author:** ![Alexander\_Johannesen](https://sea2.discourse-cdn.com/cesium/user_avatar/community.cesium.com/alexander_johannesen/32/2008_2.png) [@Alexander\_Johannesen](https://community.cesium.com/u/Alexander_Johannesen)\
**Post date:** [November 24, 2021, 3:41am UTC](https://community.cesium.com/t/forbid-camera-access-below-3dtiles/16261/7 "2021-11-24T03:41:06Z")
Hi,
You can’t set a camera position of a tracked entity, as there’s a controller for the camera now that will interfere with your forced values. If you want to control the movements of the camera of a tracked entity, I suggest you _don’t_ use the Cesium tracker, but make your own that you can control. You hook into the Cesium render cycle, and move the camera according to the entity the way you like it. More on this at the following links;
Own tracking; [Tracked Entity + camera heading - #7 by Hyper\_Sonic](https://community.cesium.com/t/tracked-entity-camera-heading/10497/7)
Specific angle; [How make camera follow tracked entity from behind?](https://community.cesium.com/t/how-make-camera-follow-tracked-entity-from-behind/8804)
Restrict moving around; [Do not move camera when setting trackedEntity - #3 by vrana](https://community.cesium.com/t/do-not-move-camera-when-setting-trackedentity/9554/3)
Cheers,
Alex
_[View the full topic](https://community.cesium.com/t/forbid-camera-access-below-3dtiles/16261)._
