I have Postgres data that I extract as GeoJSON
but then when i load them they appear inside-out
i.e. I can see the inside walls instead of the outer wall
which makes the buildings look weird.
See what I mean here:
It appears hollow
It appears hollow
Hi there,
I was able to fix by setting the perPositionHeight of each entity to false like so:
entity.polygon.perPositionHeight = false;
entity.polygon.extrudedHeight = entity.properties.height;
Gabby
I was also able to make it work by setting closeTop of each polygon to false
entity.polygon.closeTop = false;
which makes me think something else is going on because my change in addition to ‘fixing’ the inside/out problem also closed the top and left the bottom open.
Scott
Hum, I swore I tried that closed top thing! but it didn't work earlier!
Thank you very much.
actually the close Top worked not the Pre Position height
