i just download the geoserver and execute the startup.bat to run it. of course the Java is installed beforehand....btw, i changed the port from 8080 to 8090
the srtm data is preprocessed before and loaded into geoserver.
and in the same machine i use node.js to rin the web server. the port is 8080.
bobac...@gmail.com於 2015年1月8日星期四 UTC+8下午10時37分21秒寫道:
> > that is all....
> Sorry I can't help you, I don't know how to manage CORS issue with geoserver in standalone application.
I see, so geoserver can be run in another form (not under JAVA), I got it!
May I ask you how you run your geoserver and how you treat your CORS issue under that.
Hope it doesn't bother you too much..^^
I guess I already found the mistake....
because I run geoserver in different port (8090) and I run the Cesium web service in 8080 so the resource can't be shared ....
could you please tell me how to run these two service into one web server? (the same port )
I don't think that is the good approach. The easiest way is to install geoserver in a java application server (tomcat, jboss, jetty..) and after you configure the server to allow the resource share.
On the same machine you can't have two applications listening the same port (8080 or 8090)
I need to get a demo working with Cesium and Geoserver. Is there a link with the latest info about having the two technologies working together? Is the GeoserverTerrainProvider the best bet? This post is a couple of year old at this point, so I was wondering if there was any new information.
Hi @abdou, does your plugin work for latest cesium js version (1.89)? As I tried it but I am getting many issues. I’ll share my issues, but before that I want to make sure if your plugin is suitable for the latest cesium version. Please write back to me as soon as possible. I am trying to create terrain from dem data using geoserver for cesium js.
Thank you
