gltf-pipeline fails on normal compression at node_modules\gltf-pipeline\lib\octEncodeNormals.js:94:21.
I quess the reason is that gltf-pipeline from command line does not have webgl context available?
This is how I fixed my version temporarily, marked red:
// GLSLModernizer inserts its own layout qualifiers
// at this position in the source
if (context != undefined && context.webgl2) {
result += ‘#define OUTPUT_DECLARATION\n\n’;
// append built-ins
if (shaderSource.includeBuiltIns) {
result += getBuiltinsAndAutomaticUniforms(combinedSources);
// reset line number
result += ‘\n#line 0\n’;
// append actual source
result += combinedSources;
// modernize the source
result = modernizeShader(result, isFragmentShader, true);
gltf-pipeline HEAD
