How to change the default Cesium timeline ticks from 10 minutes to 15 minutes intervals?
Hi there,
While as far as I’m aware, you can’t set the tick marks with the public API, you can zoom to a specific time range using Timeline.zoomTo.
Hope that helps, thanks!
Gabby
