I’m using OSM buildings with the CesiumIonRasterOverlay:
For my taste I would like to have the buildings less shiny, I wanted to tone down Specular/Metallic and/or increase Roughness.
I followed the materials for Overlay0 and ended up at ML_CesiumRasterOverly, and found that Metallic/Specular already is set to 0 and Roughness to 1.
Clearly I’m missing something here, how can I change the material to get less shiny OSM buildings?
As a bad hack I can go to the base material and set it to full roughness:
This works in a way, have a look at the screenshot below, but I don’t want to go this way, I’d like to have more control.
Any help appreciated,
thanks & best
Andreas
The metallic/specular/roughness properties of ML_CesiumRasterOverlay
won’t matter, because the material layer blend used with overlays by default, MLB_CesiumAlphaBlendBaseColor
only blends the base color (as the name implies), not any other property.
In the default MI_CesiumThreeOverlaysAndClipping
material instance, the metallic/specular/roughness properties come from the background material layer, ML_CesiumGltf
, and it in turn uses the values from the glTF.
So, the solution here is to copy MI_CesiumThreeOverlaysAndClipping
into your project and add an extra layer at the top of the stack to override the properties:
The ML_Nothing and MLB_NotShiny are a simple material layer and material layer blend (respectively) that I created for this purpose:
ML_Nothing
is just a default material layer (no changes):
MLB_NotShiny
ignores the top layer, passes through the bottom layer, and modifies the properties we care about:
Then just set this new MI_NotShiny
as the Cesium → Rendering → Material property of the Cesium OSM Buildings tileset and this seems to achieve the intended effect:
Kevin
Hi Kevin,
as I wrote, I was missing something - thanks for the lightning-fast and super-helpful reply! The OSM buildings with raster overlay are really nice for flight simulations if you don’t get too close to them. Makes a huge difference to see a skyline passing by in the distance in comparison to just having terrain with satellite imaginary (that still looks cool at higher altitude on VFR flights, I’m not complaining!).
Best
Andreas
