I'm drawing shapes on the ground using CorridorGraphics. I'm setting a color constant for the material, e.g. like this:
var foo = viewer.entities.add({
name: 'name of XXX',
corridor: {
positions: Cesium.Cartesian3.fromDegreesArray([
lon1, lat1,
lon2, lat2
width: ww,
cornerType: Cesium.CornerType.MITERED,
material: Cesium.Color.GREEN
when I render this, I see that the color rendered is not constant, but the RGB values vary a little bit, e.g. between (27, 138, 44), (25, 142, 35), (24, 144, 33), (25, 142, 35)
I'd like to have the corridor rendered so that the color rendered is actually constant, e.g. gives the same RGB value for each pixel in the corridor from all viewpoints
see above
I'd like to record an animation of a scene with the corridors on it, with the corridors covering their area with same colored pixels
1.50, Chrome, Ubuntu 18.04
