Hi Cesium Team,
I need a support to overwrite my SRS during conversion from CityGML to 3D Tiles.
I saw this as image below:
may cesium team assist me how do I can use this?
Saharil
Hi Cesium Team,
Saharil
Hi
Are you trying to use this with the on-prem 3D Tiling Pipeline or on Cesium ion (cloud)?
Shehzan
I’m using on-prem 3D Tiling Pipeline…
Saharil
Anyway, I already solve the problem by overwrite the SRS. But I get another problem. I tried to clamp to my terrain as well but its doesn’t work, even though the result show it successfully.
I need help to make it clamp to the terrain. Hope Cesium team can assist on this issue
Thanks
Saharil
CityGML doesn’t have any notation for an object to be placed on the ground. The spec doesn’t provide an automated way to detect whether a an object should be on the ground, underground, or floating in the air.
To work around this, we detect whether a CityObject (building) has one of the follow features / sub-objects to determine if the building should be placed on the ground.
CityFurniture
GroundSurface
Track
Road
Railway
Square
ReliefFeature
LandUse
TransportationObject
If the CityObject doesn’t have any of these features, then we place it at its absolute location, which may result in it floating in the air.
Can you confirm whether your CityGML objects have one of the above features?
Sure, I will confirm it soon on next week
Saharil
Hi Shenzan,
Anyway, I was check and didn’t found the notation that you had mentioned above.
I shared data ID that I was uploaded in cesium ion : 1385797.
Any solution on how to make it happen clamp to my terrain data?
I hope your team have another ideas…
Saharil
Hi Saharil
When you are generating the building data, you will need to ensure that at least one of the properties above is used. The easiest way would be to have the bottom of the building be designated as the “GroundSurface” in CityGML. All other parts of the building can be anything else.
Shehzan
Hello Everyone,
I have a little bit info regarding SRS in CityGML I hope it will be helpful for you.
In some cases, CityGML files do not specify a spatial reference system (SRS) which is required for any viewer visualize or convert the data. We could deal with this in ion in 3 ways:
HI Muhammad Hamza
You are absolutely right that detecting the SRS on upload is almost impossible in CityGML. This is not only because of the size of file, but also the fact that CityGML does not have a single mandatory place for the SRS, and the spec even allows for multiple SRS use in the same file.
Allow the user to specify or override the SRS through the UX. Our offline tools can already do this, we just need to expose it. This can happen pre-upload.
This is something we have discussed and have an issue internally for. The pipelines in the backend support this, we need to expose it on the frontend UI.
If data without an SRS is uploaded to the server (either because we failed to detect it client side or because it came in via the REST API outside of our control) we can let the set the SRS after-the-fact and then reconvert the data.
This is more complicated that it may appear at first glance to allow users to do. While a fair idea, probably allowing override of the SRS is a more straightforward option.
Shehzan
