Earth opacity seems to be ignored rendering a huge area (polygon) filled with a color and with alpha lower than 1.
one of the vertex of this triangle, should be invisible if the Earth is "solid".
var viewer = new Cesium.Viewer('cesiumContainer',{
animation: false,
orderIndependentTranslucency: false,
baseLayerPicker: false,
timeline: false,
infoBox: false,
homeButton: false,
geocoder: false,
sceneModePicker: false,
fullscreenButton: false
var tri = viewer.entities.add({
polygon : {
hierarchy : new Cesium.PolygonHierarchy(
Cesium.Cartesian3.fromDegreesArray([10, 50, -150, 20, 20, -34])
material : Cesium.Color.fromCssColorString('#21B421').withAlpha(0.1),
arcType : Cesium.ArcType.RHUMB
i need to show some large areas of the planet
it's like "if you put some antennas in this points, the coverage is <polygon>"
i'm using
https://cesiumjs.org/releases/1.54/Build/Cesium/Cesium.js
https://cesiumjs.org/releases/1.54/Build/Cesium/Widgets/widgets.css
