I see some artifacts around the overlapping area while polygons with image fill are added. I looked into this issue (https://github.com/AnalyticalGraphicsInc/cesium/issues/4782), and the suggested workaround didn't help me. So, I tried to workaround by displaying polygons at different height so that there won't be z-fighting issue. However, I came across the different issue now, which is as follows:
I've entities each with its image added to a datasource which are at different height starting from 0. When any entity is added to or removed from the datasource, the heights of entities are adjusted such that it starts from 0.
The problem that I have is that Cesium doesn't clear the image when I try to remove an entity from the datasource and adjust the height of the remaining entities. However, if I don't adjust the height after removing the entity, it works.
Sample example:
To reproduce the issue:
- Click "Add first entity"
- Click "Add second entity"
- Click "Remove second entity"
Expected: Removes the second entity along with the image.
Actual: Doesn't clear the image.
But, when I comment out line#11, it clears the image.
Any help would be really appreciated.
Hari
