Incorrectly single-sided polygons
In the example 3D Tiles dataset from Remoscape linked below, the instanced tree leaf polygons are double-sided without backface culling. But in Cesium for Unreal 2.26 in Unreal 5.7.4 they appear single-sided and backface-culled. I’m not sure if it worked better in previous versions, but it works fine in both CesiumJS and Cesium for Unity 1.23.2 (Unity 6000.4.9f1). So it should probably be considered a specific bug in Cesium for Unreal, right?
https://remographdownloadstorage.blob.core.windows.net/downloads/Sturefors_3D_Tiles.zip
Hey @AndreasRemograph,
I’m just checking with the team about what the expected behaviour in Unreal is and if there’s any known limitations here. I’ll get back to you when I know more!
Cheers!
Hi @AndreasRemograph,
This is indeed a known limitation in Cesium for Unreal. We have a GitHub issue to track this here.
The best workaround would be to make a copy of the MI_CesiumThreeOverlaysAndClipping material and enable the Double-Sided property on that copy. Then, assign it to the Material slot on the Cesium3DTileset that requires that behavior.
We’d definitely like to make this functionality built-in so that you don’t have to do anything manually, but that’s the current state of things. :') Let us know if this helps for now!
