# Intermittent black line rendering artifacts when adding images via Entity
**URL:** <https://community.cesium.com/t/intermittent-black-line-rendering-artifacts-when-adding-images-via-entity/46435>\
**Category:** CesiumJS\
**Created:** [June 5, 2026, 3:38am UTC](https://community.cesium.com/t/intermittent-black-line-rendering-artifacts-when-adding-images-via-entity/46435 "2026-06-05T03:38:28Z")\
**Showing post:** 4
**Author:** ![szkwen](https://avatars.discourse-cdn.com/v4/letter/s/df788c/32.png) [@szkwen](https://community.cesium.com/u/szkwen)\
**Post date:** [June 17, 2026, 2:42am UTC](https://community.cesium.com/t/intermittent-black-line-rendering-artifacts-when-adding-images-via-entity/46435/4 "2026-06-17T02:42:26Z")
> [@darcyvdd](#):
> - Are you drawing to the same canvas object in place each frame, or swapping references?
Hi @darcyvdd,
Thanks for your reply.
Let me clarify point 3 first:
**Are you drawing to the same canvas object in place each frame, or swapping references?**
I’m intentionally using a double-buffered canvas approach (swapping between two canvas instances) to work around a known issue reported in the Cesium community:
[BUG: CallbackProperty for ImageMaterialProperty image doesn’t update image](https://community.cesium.com/t/bug-callbackproperty-for-imagematerialproperty-image-doesnt-update-image/5254)
In my implementation, I alternate canvases like this:
```javascript
curCanvas = curCanvas === 'a' ? 'b' : 'a';
This is necessary because updating the same canvas in-place does not reliably trigger texture refresh in Cesium in my case.
**Point 2: Is it a video element or some other image source?**
It’s an image source (bitmap), rendered via:
```javascript
activeCtx.drawImage(bitmap, 0, 0);
**Point 1: Is it a element drawn each frame in a requestAnimationFrame loop?**
It’s not strictly requestAnimationFrame. I’m using a timed update loop:
```javascript
setTimeout(() => {
    // Alternate canvases
    const activeCanvas = useCanvasA ? canvasA : canvasB;
    const activeCtx = useCanvasA ? ctxA : ctxB;
    activeCtx.drawImage(lastBitmap, 0, 0);
    currentCanvas = activeCanvas;
    useCanvasA = !useCanvasA;
    // Ensure it is initialized only once.
    if (!fmvEntity) {
      fmvEntity = cesiumViewer.entities.add({
        polygon: {
          hierarchy: new Cesium.CallbackProperty(() => currentHierarchy, false),
          material: new Cesium.ImageMaterialProperty({
            image: new Cesium.CallbackProperty(() => currentCanvas, false)
          classificationType: Cesium.ClassificationType.TERRAIN,
  cesiumViewer.scene.requestRender();
}, 33);
I also explicitly call `scene.requestRender()` to force re-rendering in request render mode.
And this is my [sandcastle](https://sandcastle.cesium.com/#c=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). After starting it, when I zoom in and out on the map, I can clearly see flickering black lines.
_[View the full topic](https://community.cesium.com/t/intermittent-black-line-rendering-artifacts-when-adding-images-via-entity/46435)._
