Interpolation path example convert to jpg
Hi Gabby,
I am currently working on interpolation example in cesium in which the path is calculated by using computeCirclularFlight. The path is created by using this function, Now what I want is convert this path in one of the image format so that I can use this in addImageryProvider function.
Please help me to solve the issue.
Hi Mahesh,
This doesn’t seem like a typical use case. Can you provide some background as to why you want to make a path into an imagery provider?
Do you just need to draw circles on imagery at runtime? If so, you might want to take a look at creating a custom imagery provider that draws to a 2D canvas, like in GridImageryProvider.js.
Gabby
Hi Gabby,
I am trying in single code there should be various path, In which I want this path should be provided using imagery provider.
I’m still not entirely clear on what you’re trying to do here, but it sounds like you’d need to create a custom imagery provider like I’ve stated above.
