Newbie question. I used qgis2threejs plugin to convert a raster data into gltf format. I want to place it in the correct position on the cesium globe. The data is bounded by a box of upper left corner of N36/E138 and lower right corner of N35/E139.
For most sandcastle examples, I see small objects, i.e. a plan, a building. I am wondering is there any way to geolocate the gltf for a large area of map?
We are trying to visualize 3d flood data on top of the terrain. Currently I am explore all possible directions - gltf, cloud points, 3dbm ...
fuji.gltf (5.57 MB)
