In my batch table, I has a array typed column named 'ids' which stores the data like ["AA|XXXX","BB|XXXX yysfdf","CC|dfdsf|dfssxx"]
In my idea, the 'ids' column is used to styling. if the array value ${ids}.indexOf(some value) !== -1, then color the feature.
But I can not found any style expression function like Array.indexOf.
I try to use regExp and convert the array to string "String(\{ids\}\)", but it's not good enough for the problem, because String\({ids}) is too many chars to get good performance. Another reason is that the id string contains many unexpected chars conflicting with regex expression.
