Issue loading gltf with webpack
I’m using webpack and cesium. I’m getting the error visible on the attached screenshot.
var Cesium = require('cesium/Cesium');
require('./css/main.css');
require('cesium/Widgets/widgets.css');
var modelMatrix = Cesium.Transforms.eastNorthUpToFixedFrame(
    Cesium.Cartesian3.fromDegrees(-75.62898254394531, 40.02804946899414, 2000.0));
var model = viewer.scene.primitives.add(Cesium.Model.fromGltf({
    url : 'data/Model2.glb',
    modelMatrix : modelMatrix,
    scale : 20000.0
viewer.zoomTo(model);
Cesium 1.60
MacOS
Firefox
This is actually not a problem not an issue with webpack. You’ll see the same error if you try it in Sandcastle:
url : '../../SampleData/models/CesiumAir/Cesium_Air.glb',
scale : 20000.0
The problem is the viewer.zoomTo method does not take a model. You could try passing in the position of the model and offset, with the viewer.camera.flyTo or viewer.camera.zoomTo methods, or use an Entity which will allow you to just do viewer.zoomTo(model) like in this example:
https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=3D%20Models.html
Let me know if that helps.
Thanks, I thought that viewer.zooTo was equivalent to viewer.camera.zoomTo. Thanks for the feedback !
Glad to hear that worked!
What kind of project are you working on?
Mostly on 3D landscapes visualization.
