Issue with intersecting holes in PolygonHierarchy
I recently started to work with PolygonHierarchy structure and I came up with some cool stuff. (see dual_no_intersect.png)
The problem occurs when 2 circles (or more) are intersecting with eachother (see dual_with_intersect.png). As you can see, there are some artefacts on the shape when 2 holes intersect.
The outer polygon is quite big and it looks like those artefacts tends to the bottom left corner of the polygon.
Here is the code sample I use to do this:
var fogHoles = ;
var fogBoundaryBox = [
            -50.0, 45.0,
            30.0, 45.0,
            30.0, 20.0,
            -50.0, 20.0
var fogEnabled = false;
var fogOfWarPolygon = viewer.entities.add({
  polygon : {
    hierarchy :
      positions : Cesium.Cartesian3.fromDegreesArray(fogBoundaryBox),
      holes : fogHoles
    material : Cesium.Color.BLACK.withAlpha(0.5)
function digNewFogOfWarHole(id, newHoleUtmPositionsArray)
  var indexToRemove = -1;
  for(var i=0; i<fogHoles.length; i++)
    if(fogHoles[i].id == id)
      indexToRemove = i;
  if(indexToRemove!=-1)
    fogHoles.splice(indexToRemove, 1);
  var posUtmArray = newHoleUtmPositionsArray.split(";");
  var finalUtmPosArray = ;
    for (var i = 0 ; i < posUtmArray.length ; i++)
    var posUtmArray_data = posUtmArray[i].toString().split(",");
    var utm = {
        northing : parseFloat(posUtmArray_data[2]),
        easting : parseFloat(posUtmArray_data[3]),
        zoneLetter : posUtmArray_data[0],
        zoneNumber: parseInt(posUtmArray_data[1])
    finalUtmPosArray.push(utm);
  var newHoleLLPositionsArray = ;
  for (var i = 0 ; i < finalUtmPosArray.length; i++)
    var LatLong = UTMtoLL(finalUtmPosArray[i]);
    newHoleLLPositionsArray.push(LatLong.lon);
    newHoleLLPositionsArray.push(LatLong.lat);
  var newHoleStruct = {
              id,
              positions : Cesium.Cartesian3.fromDegreesArray(newHoleLLPositionsArray)
  fogHoles.push(newHoleStruct);
function updateFog()
  fogOfWarPolygon.polygon.hierarchy = {
        holes : fogHoles
Basically, I have a function somewhere that call "digNewFogOfWarHole" function and every N seconds, I call updateFog() to refresh the view with new holes.
So questions:
   - Am I doing something wrong?
   - Is there a workaround to fix this?
Regards,
Hi Maximilien,
The definition is not clear, but holes may not overlap. You’ll have to combine overlapping holes yourself to get the effect you desire.
Hope that helps.
Scott
Thanks for reporting this Maximilien. I’ve open an issue in GitHub (#6238), to either remedy this behavior or clean up the docs to make this more clear.
Gabby
Hi Scott and Gaby,
Thanks for your replies.
Scott, the thing is that each circle has a specific ID and move independently over time. So basically, if I do merge shapes myself, it will be very very tricky.
Thank you for posting the issue Gaby.
Regards,
Max
