Is there a version of the obj2gltf library that doesn’t depend on nodejs to work? I want to make an application with a simple UI that uses that library internally to do the base model conversion. I managed to create a working javascript environment in the application, but the “require” statements used in the library makes it impossible for me to import and use it.
Hi there,
Unfortunately, the existing version of our obj2gltf tool is all we’re working on currently. Perhaps another community member will be able to chime in with some ideas.
- Rachel
