Packaging Failed In UE5.3
LogClass: Error: BoolProperty FCesiumGeocoderServiceAttribution::bShowOnScreen is not initialized properly. Module:CesiumRuntime File:Public/CesiumGeocoderServiceBlueprintLibrary.h
LogClass: Error: StructProperty FCesiumGeocoderServiceFeature::LongitudeLatitudeHeight is not initialized properly. Module:CesiumRuntime File:Public/CesiumGeocoderServiceBlueprintLibrary.h
LogAutomationTest: Error: UObject.Class AttemptToFindUninitializedScriptStructMembers will be marked as failing due to errors being logged
PackagingResults: Error: Unknown Error
@Amr_Fayad This issue was fixed in Cesium for Unreal v2.18.0, so updating to the latest version if possible would solve this. However, I have to assume that the reason you’re using an older version is because v2.17.0 is the last version we released for Unreal 5.3. If you’re not able to update to 5.4 or later, you can try using the fix directly, though you will have to build it from source.
