I have this problem where paths where I add alpha to the material colour gets drawn above everything else. Here are two examples first one without transparency:
entity.path = {
material : competitor.cesiumColorDefault, // just a normal Cesium Colour
width : 4,
trailTime : this.tailLength,
leadTime: 0,
resolution : this.tailLength
And then one with transparency.
entity.path = {
material : competitor.cesiumColorDefault.withAlpha(0.75),
width : 4,
leadTime: 0,
As can be seen the alpha is added but draws path on top of the rest which isn’t the desired outcome.
Am I doing something wrong or is this possibly a bug? I’m using the latest 1.29 version but this has been a problem with previous versions as well.
