For reference the RGB for that color is: 205,237,205 - or #cdedcd in HEX. Here the link to the google color picker with it set: google color picker - Google Search
I uploded this model to cesium ion to see how it looked and it’s a bit off from the style guide. It just looks a bit greyer or bluer. It’s hard to say what exactly- just not green enough?
I get that rendering is not really easy but in this case there is no other lights or environment so to speak of so I would expect it to match the base color factor pretty closely.
I compared the model in a few other viewers and they’re all a bit different really.
Here’s a screen shot for comparison across a few application including Ion
There are a variety of lighting factors in CesiumJS. I believe this apparent blue tint is due to the default settings in CesiumJS attempting to mimic atmospheric lighting. Mainly, image-based lighting gets applied to the model based on a simple environment map with a lot of blue contribution from the sky.
For example, here is box.glb with the default sun lighting and IBL at the default
Nice to see there is a solution!
I am still stuck with the blue tint… I want to stay as close as possible to the original model’s colors without external lighting influence. I had the desired colours with
glTF 1.0 and Cesium 1.96, but now I have the blue tint with
glTF 2.0 and Cesium 1.101.
Can you provide the source code or hints on how to achieve this ?
with a single white directional light and IBL contributions disabled
var model = Cesium.Model.fromGltf({
imageBasedLighting: new Cesium.ImageBasedLighting({
imageBasedLightingFactor: new Cesium.Cartesian2(0, 0),
luminanceAtZenith: 0
Perhaps increase the model’s lightColor since there is not longer a contribution from IDL? You can increase the value beyond 1.0 and the contribution from light sources will be scaled accordingly.
If you still not getting the results you’re expecting, perhaps a custom shader will give you the flexibility you need.
I do understand that it’s unexpected that this tint is applied, though I’d expect IDL to be the main contributor to that.
