I’m starting to look at Cesium for some real-time data visualisation, where pins will be created either from a polling service or web sockets. For simplicity’s sake, I like the idea of using the PinBuilder, but not that according to the source it only uses the alpha layer and ignores the colour information. As such, using a JPG will just result in a plain white block in the Pin. Before I start playing around with the source, I wondered if there was a) a more elegant solution (I’ve got the images appearing fine by just adding the JPG to the billboard, but I like the Pin concept), or b) something in the works that you might have that would solve this.
Thanks a lot, and great framework - it’s been a pleasure to use so far.
