I’m having a problem with Cesium 1.46, Firefox, Edge (but not Chrome) - I get the following stacktrace when switching to another imagery provider.
This doesn’t make any sense, but in the function displayCredits() the reference to childNodes ie
var childNodes = container.childNodes;
seems to fail in FF & Edge when the remaining nodes are removed at the bottom of the method (childNode.length does not change after removeChild() is called):
while (domIndex < childNodes.length) {
container.removeChild(childNodes[domIndex]);
If I replace the reference ‘childNodes’ with ‘container.childNodes’ (ie. not using the reference) then the problem goes away.
I can’t reproduce this in sandcastle.
undefined
Error: NotFoundError
removeChild@http://localhost:8080/ActiveFlightDemoModule/activeflight/bower_components/webcomponentsjs/webcomponents.js:1878:19
displayCredits@http://localhost:8080/ActiveFlightDemoModule/activeflight/Cesium/Cesium.js:204229:13
CreditDisplay.prototype.endFrame@http://localhost:8080/ActiveFlightDemoModule/activeflight/Cesium/Cesium.js:204554:9
render@http://localhost:8080/ActiveFlightDemoModule/activeflight/Cesium/Cesium.js:232612:9
tryAndCatchError@http://localhost:8080/ActiveFlightDemoModule/activeflight/Cesium/Cesium.js:232618:13
Scene.prototype.render@http://localhost:8080/ActiveFlightDemoModule/activeflight/Cesium/Cesium.js:232662:13
CesiumWidget.prototype.render@http://localhost:8080/ActiveFlightDemoModule/activeflight/Cesium/Cesium.js:242724:13
render@http://localhost:8080/ActiveFlightDemoModule/activeflight/Cesium/Cesium.js:242105:25
Thanks for your help,
Peter
