I have two data sources (geoJSON) that I want to be created into billboards. The original one is loaded when Cesium starts using a promise (code taken from https://cesium.com/docs/tutorials/cesium-workshop/) and is fully working. When the user presses a button, I want to be able to delete all of the existing billboards, and replace them with the second data source. I have attempted to do this through a second promise, but the promise never hits, so I am wondering if I am going about this in the incorrect manner.
I have a function called dataToGeoJSON that returns a geoJSON file stored as a variable called geoJSON. I then add the promise, just as I did for the original data-
var updatedMetersPromise = viewer.dataSources.add( Cesium.GeoJsonDataSource.load(geoJSON, geojsonOptions));
Here is the promise function-
updatedMetersPromise.then(function(dataSource) {
console.log("in updatedMetersPromise"); // Add the new data as entities to the viewer viewer.dataSources.add(dataSource); meters = dataSource.entities; // Get the array of entities var metersEntities = dataSource.entities.values; for (var i = 0; i < metersEntities.length; i++) { var entity = metersEntities[i]; if (Cesium.defined(entity.billboard)) { [set billboard properties] } }
}).catch(function(err) {
console.log('in .catch promise from updated promise'); console.log('error: ' + err);
As I said, this promise function never runs, nor does it print an error. When adding subsequent data sources do you have to use a different method?
Also, from reading the forum, it seems that deleting existing billboards is a slow process. From this sandcastle it says to remove all of the billboards you can call viewer.entities.removeAll();. I have tried this, as well as a loop such as this, but neither have worked. Am I missing something?
for (var i=0; i<viewer.dataSources.length; i++) {
console.log("remove entity") var entity = viewer.dataSources[i]; viewer.dataSources.remove(entity) }
I am sorry this is kinda two topics in one question. Thanks in advance!
