Rectangles turn into trapezoids when using the Columbus View
Hi all,
If I use the Box example from the CesiumJS sandcastle and I switch to the Columbus View, then the rectangular shapes of the boxes turn into trapezoidal shapes, with the width at the top being smaller than the width at the bottom. The higher the boxes, the more evident this effect becomes (see screen capture below). The use of Orthographic Projection doesn’t reduce the effect.
Is this the expected behavior for the Columbus View?
Thanks
