Remove the area outline
How do I remove area contours? Preserve the lines at the area splice
How to achieve edge glow
Hi there,
If you are using Entities, you can disable the polygon outlines by passing the option outline: false.
For the glow effect, you will likely need to create a custom material. Do you have any experience with wringing glsl or shader code?
