Hello, I have a problem … When you rotate the 3D object is detached from the image provider … How I can fix it? … I am using data GeoJSON … Thanks for the help
original image
image with rotation
original image
image with rotation
This is my code
Cesium.Math.setRandomNumberSeed(0);
var data = Cesium.GeoJsonDataSource.load(‘…/…/SampleData/mzatte1_region.geojson’);
data.then(function(dataSource) {
viewer.zoomTo(dataSource);
// Traer el conjunto de entidades
for (var i = 0; i < entities.length; i++) {
//Para cada entidad, crear un color al azar basado en el ID de manzana
var entity = entities[i];
if(entity.properties.area<=1000.00){
entity.polygon.material = Cesium.Color.ALICEBLUE;
}else if(entity.properties.area<=5000.00){
entity.polygon.material = Cesium.Color.LIGHTBLUE;
}else if(entity.properties.area<=50000.00){
entity.polygon.material = Cesium.Color.CORNFLOWERBLUE;
}else if(entity.properties.area<=100000.00){
entity.polygon.material = Cesium.Color.STEELBLUE;
}else{
entity.polygon.material = Cesium.Color.NAVY;
entity.polygon.outline = Cesium.Color.BLACK;
entity.polygon.outlineWidth = 5;
entity.polygon.stRotation = 0.0;
entity.polygon.extrudedHeight = entity.properties.area/500;
}).otherwise(function(error){
//Display any errrors encountered while loading.
window.alert(error);
Help
The main cause of a problem like this is having geometry that does not exactly lie on the surface of the globe.
Do you have terrain on? Do your polygons have a non-zero height away from the surface?
Could you provide me with some sample data if you are still having a problem with this?
Hannah
