Hi everyone!
I need to limit the user’s possibility to rotate the globe only clockwise (or Counterclockwise, is the same);
I think I should put something inside this function:
viewer.scene.preRender.addEventListener(function() { ....});
but I don’t know what…
Thank you very much for any suggestion!
Luca A.
Jacky
March 30, 2022, 10:59am
#2
This should not related to cesium. It should be a Javascript approach. You can avoid mouse dragging for certain directions. Check this stackoverflow link.
I hope it will help you.
Hi @luca.affini ,
I agree with @Jacky ’s suggestions. The simplest solution likely leans on a JavaScript approach (and not the CesiumJS API).
-Sam
