I just updated to version 1.50, and I get RuntimeError: "undeclared identifier 'AtmosphereColor'"
Please help...
Please help...
Thanks for letting us know about this!
Can you share your code or the full error? Is there a particular line of code that’s causing this error?
No paticular line of code.
I am loading it using angular 6.
When I downgrade to 1.49 it is working fine
Can you post the full error message you’re getting?
Does this happen with the Hello World example you get with Cesium? (from here https://cesiumjs.org/downloads/)
Hey! Can you also share some code from the Angular part in case something is missing there? Thanks!
