# Set location manually for 3D model with metadata
**URL:** <https://community.cesium.com/t/set-location-manually-for-3d-model-with-metadata/14547>\
**Category:** Cesium ion\
**Created:** [July 23, 2021, 1:09am UTC](https://community.cesium.com/t/set-location-manually-for-3d-model-with-metadata/14547 "2021-07-23T01:09:19Z")\
**Showing post:** 6
**Author:** ![Matt\_Boyd-Surka](https://sea2.discourse-cdn.com/cesium/user_avatar/community.cesium.com/matt_boyd-surka/32/5511_2.png) [@Matt\_Boyd-Surka](https://community.cesium.com/u/Matt_Boyd-Surka)\
**Post date:** [July 29, 2021, 6:14pm UTC](https://community.cesium.com/t/set-location-manually-for-3d-model-with-metadata/14547/6 "2021-07-29T18:14:08Z")
Hi @Chat, here is a post that explains how you would achieve per-feature picking: [Per Feature Data - CAD/BIM Models](https://community.cesium.com/t/per-feature-data-cad-bim-models/11740)
Each feature needs to be a separate `dae` file with its own info in the `kml`. In that post, there’s an example excerpt of a `kml` file that enables per-feature selection.
You won’t be able to adjust the tileset location manually using this method, but a workaround would be to obtain the correct location through a separate step, and then put that location in the `kml` file. For example, you could upload the building as a non-georeferenced model, move it to the correct location using Adjust Tileset Location, and then copy the resulting lon/lat/height into your `kml` file.
_[View the full topic](https://community.cesium.com/t/set-location-manually-for-3d-model-with-metadata/14547)._
